Other Parts Discussed in Thread: GPCRA0,
Hi, I’m trying to use GPCRA0 to generate gg file for bq40z80 gauge. The results have Qmax set to the actual mAh rating of the battery. With scaling factor set, I’m assuming Qmax should scale as well? What’s the correct procedure? What I will try next:
- Do ChemID using the true current reading without any scaling.
- Program the ChemID and then use the scaled down current for GPCRA0 tool to get the gg file.
