Hello team,
I received a question about reverse current of TPS7A91. I would appreciate if you could give us some advice.
Some LDOs recommend a discharge circuit outside the device between VOUT and VIN in consideration of when VIN <VOUT.
Regarding "TPS7A9101DSKR", there was a description about discharge circuit in the data sheet, but it is okay to think that the reverse current does not occur because the current flows through the discharge circuit when the input power is down?
Best Regard,
Ryotaro Fukui
