If I pull TS low to disable charging, does PG still stay low to indicate "Power good"?
The block diagram just shows a "CHARGE CONTROL" block between them
The /PG pin should still stay low. The only condition for it is to indicate a valid input source. It should not be affected by the TS pin state.
