Part Number: TPS54618-Q1
My customer would like to know what is the difference between TPS54618-Q1 and TPS54618C-Q1?
If my customer is just in sample run, can we use TPS54618-Q1 first?
Thank you.
Thank you.
Hello user,
TPS54618C-Q1 has improved robutsness.
I woud recommend you move your design to the TPS54618C-Q1. Also in terms of supply as TPS54618-Q1 is labeled as "Last time Buy".
Thanks a lot!
Dorian
Yes, you can replace them directly. TPS54618C-Q1 and TPS54618-Q1 are BOM to BOM and pin to pin replacable.
The 'C' version is released to improve the automotive robustness and reliability. There is no change in the functionality and it is fully compatible in performance.
Hello user,
Do you have any further questions here ?
I will close this thread due to inactivity.
If you want to reopen this thread, just reply below.
Thanks a lot!
Dorian
