Hi Team,
Could you review TPS54325's schematic quickly?
You can access the schematic from here(Internal link)
Let me know if you find out any no good points in the schematic.
Takashi Onawa
Hi Team,
Takashi Onawa
Hi Onawa-san
If the schematic is confidential, can you please send us an email for the review?
Gerold
Onawa-san,
What is the VIN slew rate? What is the timing of the EN signal relative to VIN? As per datasheet, PG pull-up resistor needs to be ideally connected to VREG5 via a high enough resistor (25k to 150k). The 4.4A inductor current rating could be an issue especially since you are ramping up fast with a small soft-start cap and this device has valley current protection. So, the peak current levels could be as high as 6A-7A plus depending on ripple.
Amod
