Other Parts Discussed in Thread: TPS543620
Hey all -
It seems that the RPY0014A land pattern available for download from UltraLibrarian through TI's product page for the part is incorrect.
It does not match the recommended land pattern. It also has Pin 11 drawn incorrectly enough for me to question it.
Does anyone know if the datasheet recommended land pattern has been tested and is correct?
It is also concerning, as there are some kind of bizarre spacings: ie. 0.7006mm for a nominal 0.7mm dimension on the package drawing. It's also missing a couple dimensions required to define pin 10.
If someone can help clear this up before I send out a PCB design, I'd really appreciate it.
thank you -
Stephen
