I have a PCB with the following circuit:
If you connect a 24V lead-acid battery, the housing of the TPS55165 gets a crack at pins 4-6. After that, the chip no longer works.
The problem can be reproduced with 30V on a laboratory power supply. The problem does not occur with a 12V lead-acid battery.
Warum wird der Chip zerstört, obwohl er bis zu 40V funktionieren sollte laut Datenblatt? Wie kann das Problem behoben werden?
