Hi Team,
customer is looking for a 12V/25mA common low cost linear charger. (1S)
per checked on the web I found several solution and would like to check with you any other recommendation?
Thanks!
Patty
Hi Team,
Thanks!
Patty
Hi Patty,
Are you looking to charge with a 12V input? Most of the linear chargers with power path feature an overvoltage protection feature that will cause the device to enter standby mode if the input voltage exceeds the OVP specification
