I am using two LM73100PWR ICs as ideal diodes in an OR configuration between two power supplies to my system. The two power supplies cannot mechanically ever be plugged in at the same time, so only one LM73100PWR will ever be on at a time.
Is it ok to route the PG pins together to the same MCU I/O?
If the LM73100PWR is not powered on, will the PG pin be floating, or will it be tied to ground?
Thank you.
