i'm trying to work out the comp loop values using the web based power designer. the tool seems to get stuck on L values (very narrow range), and i don't trust the loop comp values as a result. if i look at the equations for the values, i get x10 or more different results for the Rc, Cc, Croll. i then tried the power stage designer tool, and used the loop calculator to try and get results. again i got results quite different from the other tools (although there are parameters in the Gain info i don't understand). I am doing this for all four rails, i'd like to see about getting the same values for all four if it's possible. any guidance?
