RSL is restricted under 1kΩ on the app note as below;
What is this restriction caused by?
Kuramochi
Kuramochi
Hello Kuramochi,
Please have a look at Figure 8-5 in the datasheet at page 9. As you can see, the current limit is with the external RSL resistor dependent on the duty cycle and if you see the slope of this dependency with a 1 kohm resistor, a value bigger than this makes the current sense signal measurement very inaccurate and extremely dependent on this resistor. So I would even say that keeping this resistor below 1 kohm makes sense.
But if the customer wants to use even higher resistors, this is possible, but most probable, at higher duty cycles no output current will be available.
Brigitte
