DCR010503: Connect 2 DCR010503U outputs to increase power.
Part Number: DCR010503
My customer may require >1W Isolation output.  Can he connect 2 DCR010503U outputs with Schottky diode for reverse protection to achieve >1W output?   If no, please let us know the solution.
Thanks and best regards,
M.HATTORI.
  • Hattori-san,
    The issue I foresee is power balancing. It's unlikely that both devices will have output voltages close enough to ensure equal power output with a diode OR. More likely one will try to supply all the power while the other does nothing or very little. I recommend looking into a different device if >1W is required. LM
    -Sam
