Hi Team,
we found datasheet of LM5041 is quite simple, we can not found detail design guidance and calculation(like comp SS CS calculation), do you have any design tools or guidance documents to share?
And another question is: when customer power off LM5041 circuit(UVLO trigged), they found the buck will power off firstly, then push-pull power off, is there any way to make push-pull power off firstly then buck power off?As customer found if buck power off before push pull, output capacitor`s voltage will still keep high voltage and that`s not customer want.
Thanks.
Regards, Sunny
