Hi team,
My customer is considering to use the TLV741P. The d/s recommends minimum 1uF for output capacitor. Could you tell me the minimum effective capacitance required for the output cap?
Yamaguchi
Hi team,
Yamaguchi
Hello Yamaguchi,
The minimum effective capacitance in this case is 1uF.
- Stephen
Hello Stephen,
Thanks for your reply. Doesn't this device allow nominal 1uF cap for output since the minimum effective capacitance is 1uF?
Yamaguchi
Hi Takashi,
On further review, while the datasheet does not list it as such, you are correct: a 1uF capacitor is required and this assumes 50% derating. So the minimum effective capacitance is 0.5uF.
Let me know if you have any other questions.
- Stephen
