Dear TI Team
When I investigated the difference between TPS6590378 and TPS6590379, I found the following link.
https://e2e.ti.com/support/power-management/f/power-management-forum/723506/faq-tps659037-the-difference-between-tps6590378-and-tps6590379
I checked the above link and confirmed that there is a difference between TPS659378 and TPS659379 as shown in the connection method (see the figure below).
(The red circle is the difference.)
But I don't know the reason for the connection method.
For example, if you check the sequence, there are the following differences.
In other words, I think that the TPS659378 and TPS6590379 have different connection methods with the CPU due to the different sequences.
Is this perception correct? If there is anything else, please let me know.
Y.Ottey
