Customer Question-
We have a housekeeping IC that can perform a hard reset. This IC currently outputs an active-high RESET signal for 1 second. When this signal is high, we expect all power sources to cut power to the system. When this signal goes high, I would like the BQ25600D to enter HiZ mode so that the USB power path stops supplying power to the system.
Is there a way to force the BQ25600D into HiZ mode using an external signal? We could add a loadswitch on VBUS. We could even just short REGN to GND. But i am curious if this PMIC supports any more elegant solutions.
Thanks!
