TPS92638-Q1: Reg. FAULT pin External Setting
Part Number: TPS92638-Q1
Hi TI,
Pls let me know whether the FAULT pin of TPS92638/TPS92630 should be tied high or left open to switch off all the output channels & ICs in the chain, during both Single/Several LED SHORT and OPEN failure.
The Fault Table in the Datasheet is very confusing. It is very confusing.
Pls revert at the earliest.
