Hi team,
If I remove the Vin, what status would FLTb pin be? The test result in datasheet shows that FLTb pin would hold low. While the datasheet also tells that 'V(IN) falling below V(UVF) = 2.1 V resets FLTb', what does it mean? It seems indicate that the FLTb would be changed to high since the device has lose the power. So please help confirm the status of FLTb. Also the status of PGOOD pin when Vin is removed (the device lose the power).
Thanks!
Jayden Li
