Hi Team,
Customer wants to know which thermal spec can be used for temp calculation.
Is it 'junction to board' or 'junction to top' or 'junction to air' ?
Thanks!
Andrew
Hi Team,
Thanks!
Andrew
Hi Andrew
If you can measure the case temperature, then you can use Psi-JT to calculate the junction temperature.
Please refer to this article https://www.ti.com/lit/ug/sluu484/sluu484.pdf
If the intent is to get a rough estimate of Tj based on a given Ta, then you can use the thetaJA of the EVM (it assumes that your layout is similar to the EVM) and use below formula.
Tj = (ThetaJA * Pd )+ Ta
If you use the WEBENCH tool, it will help calculate the Tj as well.
Gerold
