Other Parts Discussed in Thread: BQ76PL455EVM
I have designed on the same PCB 2x16 cells BMS module using two BQ76PL455 ICs with Tiva C Series TM4C123G MCU. in the design part everything was done by your guiding documents. I know that you have already made a sample code with TMS570004 but I am trying to convert your shared code for Tiva.
right now I am trying to complete the code part for Bq76pl455 however I have some questions and hopefully through this forum I can get regarding answers by your help as quickly as possible.
questions:
1-) I have read some people comment on the sample code TMS570004 and BQ76PL455EVM problem that they had faced during coding. if I am not mistaken in the one of forum you were saying that the code which we shared is just skeleton and you have to rearrange it have not you? do I understand correctly? if that it is can you share with me what steps I should follow? I mean I have already checked bq76PL455A-Q1 Software Design Reference and other datasheets out yet I need a flowchart of code which I can sticky with that.
2) for beginning just to see communication, respond and debug, I would not connect batteries to the System, so I am planning to power up separately both of ICs in the stack by supplying Vp,VDIG and VIO pins regarding voltage values (if there are other pins to supply power please let me know). however I am very attentive to not cause any error that by connections. that's why when considering this setup can you please help me to illustrate the system I want to build?
please let me know you what you think of?
I do need to complete this project as soon as possible
Thank you for your understanding
Best Regards
Mahmut Demiryent
