Other Parts Discussed in Thread: USB2ANY, BQ25731, BQSTUDIO, EV2400
BQ25731EVM connected to USB2ANY.
The connection lamp is green.
But i unable to change the charge current limit with the TI Charger GUI.
What I doing wrong?
What I doing wrong?
Hi Oleg,
Let me collect some more information so we can begin debugging this. Are you able to read and write to the other registers normally? Are you only having trouble writing to the ChargeCurrent() register, or does this apply to other registers as well?
Angelo
Many registers allow you to work with them. But 25% do not allow you to change the values in any way. Only when BQ25731 is no connection.
https://youtu.be/Ih0PwiSHlFw
Hi Oleg,
Thanks for the detailed information. The BQ2573x GUI has a glitch, and we are working to update it. In the meantime, do you have an EV2400 or EV2300 that you can use for evaluation with BQStudio? If so, then I can send you the .bqz configuration file.
Angelo
