Hi Team,
Good day. Please help to check our customer's concern.
It works normally if using battery management studio but for our customer's convenience they have develop their own software to calibrate it automatically for production purposes.
Now they need to confirm some details on the technical references. The technical reference is sluuax0c ( www.ti.com/.../sluuax0c.pdf ) on page 119
There are 3 points that need to confirm with you if there some corrections need to be done.
1. Does this regulation follows IEEE-754? they found different result if using this algorithm. Only the byte 2 and byte 3 were the same with those of IEEE-754.
2. "Byte 2 OR with 0x80", what's Byte 2 here, is it byte 2? The sign bit is the highest bit, why Byte 2 not Byte 0 ?
3. exp = -128, tmpVal = 2**(8-exp) x mod_val -128 it's more larger than a byte value.
Looking forward to your response. Thank you.
Jonathan
