Hi team,
Regarding output cap selection, datasheet states effective cap need to be at least 50uF.
In the calculator, the calculated cap can be much lower, say 25uF. If 50uF is used per datasheet, the gain margin gap will flag.
Question here is should customer follow datasheet recommendation to use minimum 50uF (effective)? Or should use 25uF (effective) per LP8863-Q1 calculator?
