In my application I'm just using only one of the output. What is the TI recommendation for second output(unused) pin connection? Should the unused output float or tie to grand.
Hi Matt,
If you tie the unused output's enable pin to ground, then I'd recommend tieing the unused output to ground as well. These extra ground connections will improve the thermal dissipation of the LDO.
If the unused enable isn't grounded then the second output should be left floating.
