Part Number: ISO5452
HI T.I Support,
1 - I use the ISO5452 as DESAT protection on IGBT. The IGBT have VCE=5V in 300A and on this current I want to protect. Please advise how to set the application to 9V - (DESAT threshold).
Can I add a Zener diode in serial ? What Part Number of diode (assume 500uA from pin DESAT flow through the Zener diode) ?.
2 - As I see in the user manual you put resistor of 10 ohm in serial to VCC1 (pin15). (Figure 54).
Please advise why 10 ohm ?. If I put 1 ohm - is it a mistake? What can happened?
Thank you
AVNER
