I am using LM5102. 50Khz signal is given as input for tOP mosfet and inverted 50khz signal is given as input for botom mosfet.
In the above circuit pin 4(HS) should connect to junction where top mosfet source and bottom mosfet drain connect. It is missed here but connected in hardware with a jumper. But the pin out HO (pin no 3) is not switching according to the input and at the same time there is switching at bottom output LO(pin no 10). Kindly helpme out whats wrong going on in the above circuit.
