I'm trying to order a sample of the PTN04050CAH 12-W, 3.3/5-V Input, Wide Adjust Output Boost Converter but after selecing the item and adding to the shopping cart all I can select from the quantity drop down is 0 which doesn't allow me to order it at all.
Is there a specific problem with the power regulation boards as I've tried it on 7 different modules and each one has the same issue.
I've tried on other items not in the power regulation section (TPL0102-100 for example) and that works fine with multiple quantities showing in the drop down.
Hope this is something that can be sorted out as there's a couple of the power modules I'd like to try on my new prototype before having to redesign things to accept different power characteristics.
Thanks in advance.
