I have ordered the above mentioned EVM and want to have regulated 3V, 3.3V and 5V output with input power supply between 3-10 V. The data sheet is not very clear for the EVM. Can anyone let me know how to kickstart on this?
Regards-
Regards-
You can adjust the output voltage of the EVM by modifying R1 and/or R2 as explained in the datasheet. Note that being a buck converter, you cannot get 5Vout when you give it 3V in. You need a buck boost converter for that, such as TPS63060.
But the EVM has already the resistors soldered and its set for 3.3V as output. Do you mean to remove them(R1 and R2) and solder resistors of required values?
Regards-
I am new to voltage regulators, so needed to confirm. Any ways, thank you Chris.
Regards-
