Other Parts Discussed in Thread: BQ24193
Understood from datasheet that bq24193 can function as autonomous charger in default mode.
In default mode, safety timer is set to 5hrs regardless of register setting.
Upon 5hrs, EN_HIZ is set to cut off buck converter and system load is supplied by battery.
In this case, does it mean the battery will be continuosly drained by system without being recharged?
Additionally, what is the tolerance for the duration set for safety timer? Example if set as 5hrs, the timer will be activated at 5hrs +/- ??
