bq2050 problem
Other Parts Discussed in Thread: BQ2050
I am using bq2050 in my project to display battery capacity. My battery size is 3200mah.
I have connected 0.1uf capacitor to RBI pin which doesnt discharge on removal of battery. So we discharge it via external resistor to reset the ic.
PROG1=L, PROG2=L, PROG3=H, PROG4=L(PFC=22528) this is the setting we did.I follow this process,
  1. Connect the new battery.
  2. reset the ic via software.
  3. Charge it to full.
  4. Then discharge to full.
  5. Discharge RBI capacitor via external resistance.
  6. Charge the battery again.
  7. Check the register values.
My problem is after this sequence my CI flag is remaining SET. Ideally it should be reset. Also NACH = LMD =PFC is observed.
Can you please help me where I am going wrong?
