  • TI Thinks Resolved
Behavior of TLV62080 when PG terminal connects to Vin terminal
Mastermind 7135 points
Hello
PG terminal of TLV62080 is written connecting to the SW terminal in datasheet.
But if PG terminal connect to VIN terminal, how does PG operate?
Yokota
  • PG is the power good pin. It should not be connected to SW. In the datasheet it is shown connected to Vout with a pull up. If you pull it up to Vin, if EN is low and Vout is 0 V, you may see PG as still good.
    Best  Regards,
    John Tucker
    BSR-MV DC/DC Applications
    “Working on an automotive power design? Read the E2E technical article Meet European Commission ADAS requirements with TI DC/DC for device recommendations and other helpful resources.”
