Other Parts Discussed in Thread: LM5060
Dear support team,
Please tell me the frequency of internal charge pump.
I want to know it if there is any effect on the noise.
Tomoaki Yoshida
Dear support team,
Tomoaki Yoshida
Hi Alex,
Thank you for your reply.
I'm looking forward to answer from you.
Tomoaki Yoshida
Hi Yoshida-san,
Can you provide more information about how this information would be used? For example, if your customer is trying to run simulations of a system level EMC environment, then they would need much more information than just frequency (of noise sources). If your customer is just trying to document all noise sources frequencies within their system, then this request seems less critical.
As you may have noticed from Alex's reply this is a lot of work and expense for TI if only for informational purposes. If more than just for information, then please provide more information and then we can go further.
Hi Eric-san,
They will do a noise test by their designed board.
There may be necessary to reduce emission noise of their board cause by the test result.
They would like to know a frequency of a charge pump of LM5060 because it may has an influence on emission noise.
There is not a problem in the present.
Do you need other informations?
Tomoaki Yoshida
Hi Alex-san,
Thank you very much for taking the time to verify the data.
Our customer becomes easier to analyze with this information.
Tomoaki Yoshida
