Can someone highlight the major differences between the LP3943 and the TLC59116? They seem like very similar devices to me.
Thank You
Hi Mike,
Both devices do not have dedicated LED engine to support breathing behavior, however, this behavior can be accomplished by keep sending i2c commands to the device adjust the brightness accordingly.
You should also take a look at LP55231, it has 3 LED engines, once the pattern is loaded, the microcontroller only needs to send a command to start the pattern. The draw back is it only has 9 channels, they will need 2 LP55231.
H L
