LMZ12003: Soldering the Exposed Pad of LMZ12003 by Hand
Part Number: LMZ12003
The datasheet for LMZ12003 suggests that its package allows for hand soldering. Are there recommended methods how to solder the exposed pad manually? Should it be done using a hot-air gun, or would I be able to make a larger solder pad (as in larger then the body of the module) in order to be able to heat up solder under the exposed pad (see attached image)?
Thanks!
