REF6041: Voltage References buffer
Part Number: REF6041
Hi
my question is about the opamp that   we use it   for  buffering  ADC  voltage reference
when reference voltage ICs  output    is a DC  voltage,  why we should use wide bandwidth op-amp  in case we want to buffer  it
what is the roll of  bandwidth of op amp here ?
thank  you
  • hi Vahid,
    you can find the answer to the first question in the section "9.3.1 Integrated ADC Drive Buffer" of the device datasheet, and figures 17/18/19 can give you a numerical indication...
    while for the 2nd question you are right, there is no indication about the BW of internal buffer, but it is a minor because, as refence voltage, you are more interested in knowing the noise level associated to it (i.e. figures 13/14/15)
    KR
    Vincenzo
  • yes my emphasis is about wide BW , about using buffer there is no doubt( either internally buffered or externally buffered ).
    thank you so much
