Other Parts Discussed in Thread: REG1117, TL431
According to the data sheet temperature drift is typical 30ppm ( max 65 ) from -40 to 85 deg C.
However could it be expected the highest output voltage is at approx. 50 deg C. like shown at data sheet page 7 figur 3, and then drop at both higher and lower temperature ?
It is basically a question of how good temperature drift correlation could be expected between output voltage from ref3030 mounted at different boards, but knowing the ambient temperature will be the same.
Geert Petersen
