Other Parts Discussed in Thread: TPS62097
Hi all
Would you minf if we ask TPS62060?
<Question1>
There is the description as follows on the datasheet P8;
"During soft start, the switch current limit is reduced to 1/3 of its nominal value I LIMF until the output voltage reaches 1/3 of its nominal value.
Once the output voltage trips this threshold, the device operates with its nominal current limit I LIMF"
We would like to confirm "the output voltage reaches 1/3 of its nominal value".
Does it mean Vref(600mV)? So, it means 200mV(600mV / 3)?
<Question2>
After current limit reached, we guess that device will stops outputting.
Maybe, it will hiccup, right?
How much is the cycle of hiccup operation?
Kind regards,
Hirotaka Matsumoto
