Dear all,
I am using the LM5107 and LM5101AMR MOSFET drivers within a boost converter to drive the switching NMOS via the low side driver. The high side driver is not used at all. From time to time the driver fails and seems to be shorted internally. Connection of LI to GND helped a lot, also connection of HB to VDD and HS to GND.
What would be the most save and most recommended connections for LI, HB and HS if the high side switch is not used?
I appreciate your answer, thanks in advance!
