Other Parts Discussed in Thread: TIDA-00478, , TPS650864
I refer to TI's TIDA-00478 Test Report.
I have a customer planning to use the TPS65218 on a Xilinx Zynq design. The customer will need to program the TPS65218 for the correct voltage rails and power up sequence .
Seems that programming the TPS65218 is not an easy task, so I need to ask the following:
Can TI provide the EEPROM settings as required for the Zynq?
How can the customer program the TPS65218 .... reading through the data sheet, and other posts on e2e, seems it is not an simple task.
Are TI able to provide samples of the TPS65218 which are already programmed for use with the Xilinx Zynq?
Erich Nast
