I discussed with a TI application engineer and he said it is possible to connect the 3 current sinks together and then drive 3 strings in parallel. Please see attached image.
The response was: It is OK to combine the sinks together. The boost control loop will normally regulate the current sink headroom of the highest voltage string, but with them all tied together, it will just regulate all three to the same regulated feedback voltage.
Can you clarify what the value of the feedback voltage is and how it is set? Also if there is a voltage variation in the 3 LED strings, how does the feedback voltage handle this variance? Is there a variance range I need to design to?
Thank you,
Elisha
