Hi all
Would you mind if we ask TPS27S100?
When negative voltage occurs at Out pin, Reverse current occurs.
And then, does the current flow into Vin via FET's body diode?
It seems that there are no back to back FETs internally.
There is the description on the datasheet P17 as follows;
"Excessive negative voltage could cause the power FET to break down. To protect the power FET, an internal clamp between drain and source is implemented, namely V DS(clamp) ."
This voltage clamp is protection for FET, right?
We recognize that there is no protection for reverse current.
Kind regards,
Hirotaka Matsumoto
