Hi Team,
My customer is evaluating our TPS7A8101. Below is the start-up(VIN, Vout, Enable) waveform also showed below:
The issue is described as below:
When Vin=5V was give(Showed in waveform, the Yellow curve), after delay about 500ms, then pull the Enable high(Pink curve), but before the Enable become high, these is Vout=0.7V, but not about 0V. This will cause problem for customer to use.
So why TPS7A8101 has output before Enable the device? Any solution to avoid this issue? Thanks.
Sulyn
