Other Parts Discussed in Thread: TPS62821, TPS62088
Is it possible to connect the VDAC via the FB pin and the resistor in the TPS6223x series and make the output voltage variable?
If yes, if TPS 62231 is adjusted to 3.0 V, is the efficiency close to TPS62231? Or will it be close to TPS62233?
Yuto Sakai
