I am trying to send a command 00 0010 to shutdown the Z95.
I have the correct configuration set for shutdown
Operation Cfg A = 6A29
Operation Cfg B = 7ED8
Operation Cfg C = 0001
[Power(Power)]
Flash Update OK Voltage = 7500
Shutdown Voltage = 9000
Shutdown Time = 10
Cell Shutdown Voltage = 2500
Cell Shutdown Time = 10
Charger Present = 4000
Sleep Current = 25
Bus Low Time = 5
Cal Inhibit Temp Low = 5.0
Cal Inhibit Temp High = 45.0
Sleep Voltage Time = 5
Sleep Current Time = 20
Wake Current Reg = 03
I have the battery board with 3 210 resistors to simulate a battery pack. I have adjusted the supply to 8.5 volts .Nothing happens when I send the 00 0010 under the Pro Command page. The pack doesn't seem to shutdown until I run the supply to 7.5vdc. Any ideas?
Mike
