  • TI Thinks Resolved
TPS40303: TPS40303 Pin function
Expert 2000 points
Part Number: TPS40303
Could you help check above questions,tks!
1. pls help check whether TI can providethe  internes Blockdiagramm for the LDRV / OC functions  of Pin9 ?
2. Pls help check if the TPS40303's Pin8(SW) connect to GND,both Pin7(HDRV ) and Pin9(LDRV) can be output normal PWM ?
  • Darren,
    2. Yes it can output normal PWM but how does the boot strap function work when SW pin is grounded?
    Mathew
