LMZ21700: Failure mode exhibited
Part Number: LMZ21700
I have observed a failure mode on the LMZ21700SILR regulator, the symptom is as follows:
When the regulator is not powered, the impedance between pin 4 and ground is 4.7 ohms.
When the regulator is powered with 12V, the output voltage is zero.
Can you elaborate on what I am seeing please, thank you.
