I want to use LP5907 (2.5V and DSBGA package) in a new design.
For some calculations and budgetting, I need some numbers for temperature drift and long term stability.
Could someone provide me these numbers?
Thank you,
Sven
Thank you,
Sven
Hello Ryan,
Thank you for your response! Because our system had some hard requirements regarding reference voltage (package size, noise, Iq), we had to go for an LDO option (REF3325-KGD was also investigated but is not preferred by project because of wirbonding, high prize and MOQ). This LDO however is not a problem because our system is fully ratiometric (slow system, temperature measurement) so that we need no high initial accuracy or low drift.
The reason that I'm interested in these numbers is that I've to map a certain temperature range to the reference level. I already took into account the 2% tolerance. But do I have to take an extra margin for drift/long term stability?
Lets say I still use this LDO after 7 years, is it still guaranteed that the output voltage (in temperature range 20-24 degrees) will be within this 2% tolerance?
Sven
