Hi Team,
customer using CSD19535KTT and found some pcs that due to leakage current too high and there is a remaining voltage present even with the FET is turned off.
resulting the output voltage will still turn on the remaining circuit components when it suppose to be shutdown
although it's specified in the DS 5.1 Electircal Characteristics
the IDDS (drain-to-source-leakage-current) MAX is 1uA
can we check with the design team on
1. what's the typical value? and how many std deviation is the cut off point? (distribution bell curve)
2. it's observed that the fail IC leakage is 0.2uA compare to 0.02uA normal IC, what the expect Max value? (1uA in the DS but really this big?)
this is to help to clarify and make their design team to decide the work around to resolve such condition.
Thanks for the help
