I am using Fusion Digital Power Designer V7.0.25.0.
I am having an KC705 evaluation board. It is not booting. Only a 12V led is glowing and LCD screen is showing power. All the other board components are not getting powered.
To debug this I used a USB-to-GPIO module with Fusion GUI. it is detecting three devices USCD9248 @ 52,53 and 54. When I am clicking "Click to configure device". A new window is opening showing different options.
On this window if I am clicking Monitor button fatal error is occurring. details of error log is attached for your reference.
Same message is appearing for all the three devices.
Kindly suggest how to solve this problem.
The contains of error log is
Overview
Application: Fusion Digital Power Designer 7.0.25.0
Operating System: Microsoft Windows NT 6.2.9200.0
.NET Runtime: 4.0.30319.42000
Memory Used: 159.00 MB
Exception
System.ArgumentOutOfRangeException: Index was out of range. Must be non-negative and less than the size of the collection.
Parameter name: index
at System.Collections.ArrayList.get_Item(Int32 index)
at System.Windows.Forms.TableLayoutStyleCollection.System.Collections.IList.get_Item(Int32 index)
at TIDP.WinForms.Controls.cv.b(Int32 A_0)
at TIDP.WinForms.Controls.cv.a(Int32 A_0, Boolean A_1)
at TIDP.WinForms.Apps.DPGUI.jz.ee(Int32 A_0, Boolean A_1)
at TIDP.WinForms.Apps.DPGUI.jz.ey()
at TIDP.WinForms.Apps.DPGUI.jz.ai0(PMBusDevice A_0)
at TIDP.WinForms.Apps.DPGUI.kd..ctor(PMBusDevice A_0)
at TIDP.WinForms.Apps.DPGUI.kf.ee(PMBusDevice A_0)
at TIDP.WinForms.Apps.DPGUI.kf.ai0(PMBusDevice A_0)
at TIDP.WinForms.Apps.DPGUI.is.ai0(PMBusDevice A_0)
at TIDP.WinForms.Apps.DPGUI.is..ctor(at A_0, du A_1)
at TIDP.WinForms.Apps.DPGUI.ap.a(TaskMode A_0, at A_1, Boolean A_2)
at TIDP.WinForms.Apps.DPGUI.at.a(TaskMode A_0)
at TIDP.WinForms.Apps.DPGUI.at.a(Object A_0, NavBarGroupEventArgs A_1)
at DevExpress.XtraNavBar.NavBarControl.RaiseGroupEvent(Object linkEvent, NavBarGroup group)
at DevExpress.XtraNavBar.NavBarControl.RaiseActiveGroupChanged(NavBarGroup group)
at DevExpress.XtraNavBar.NavBarControl.set_ActiveGroup(NavBarGroup value)
at TIDP.WinForms.Controls.cs.a(Object A_0, MouseEventArgs A_1)
at System.Windows.Forms.Control.OnMouseUp(MouseEventArgs e)
at DevExpress.XtraNavBar.NavBarControl.OnMouseUp(MouseEventArgs ev)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at DevExpress.XtraNavBar.NavBarControl.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
Loaded Assemblies
Com.Muegel.Misc
Version: 2.0.88.23072
Info Version:
<empty>
Location: file:///C:/Program Files (x86)/Texas Instruments/Fusion Digital Power Designer/bin/Com.Muegel.Misc.DLL
Public Key Token:
Com.Muegel.WindowsApp.Win32API
Version: 7.0.0.23119
Info Version:
<empty>
Location: file:///C:/Program Files (x86)/Texas Instruments/Fusion Digital Power Designer/bin/Com.Muegel.WindowsApp.Win32API.DLL
Public Key Token:
DevExpress.Data.v6.2
Version: 6.2.10.0
Info Version:
<empty>
Location: file:///C:/Program Files (x86)/Texas Instruments/Fusion Digital Power Designer/bin/DevExpress.Data.v6.2.DLL
Public Key Token: 79868B8147B5EAE4
DevExpress.Utils.v6.2
Version: 6.2.10.0
Info Version:
<empty>
Location: file:///C:/Program Files (x86)/Texas Instruments/Fusion Digital Power Designer/bin/DevExpress.Utils.v6.2.DLL
DevExpress.XtraBars.v6.2
Version: 6.2.10.0
Info Version:
<empty>
Location: file:///C:/Program Files (x86)/Texas Instruments/Fusion Digital Power Designer/bin/DevExpress.XtraBars.v6.2.DLL
DevExpress.XtraEditors.v6.2
Version: 6.2.10.0
Info Version:
<empty>
Location: file:///C:/Program Files (x86)/Texas Instruments/Fusion Digital Power Designer/bin/DevExpress.XtraEditors.v6.2.DLL
DevExpress.XtraGrid.v6.2
Version: 6.2.10.0
Info Version:
<empty>
Location: file:///C:/Program Files (x86)/Texas Instruments/Fusion Digital Power Designer/bin/DevExpress.XtraGrid.v6.2.DLL
DevExpress.XtraNavBar.v6.2
Version: 6.2.10.0
Info Version:
<empty>
Location: file:///C:/Program Files (x86)/Texas Instruments/Fusion Digital Power Designer/bin/DevExpress.XtraNavBar.v6.2.DLL
DevExpress.XtraPrinting.v6.2
Version: 6.2.10.0
Info Version:
<empty>
Location: file:///C:/Program Files (x86)/Texas Instruments/Fusion Digital Power Designer/bin/DevExpress.XtraPrinting.v6.2.DLL
DundasWinChart
Version: 7.1.0.1810
Info Version:
<empty>
Location: file:///C:/Program Files (x86)/Texas Instruments/Fusion Digital Power Designer/bin/DundasWinChart.DLL
Public Key Token: A4C03DCE5DB22406
Free.CommandLine
Version: 2.0.88.23118
Info Version:
<empty>
Location: file:///C:/Program Files (x86)/Texas Instruments/Fusion Digital Power Designer/bin/Free.CommandLine.DLL
Public Key Token:
Free.Hid
Version: 2.0.88.23119
Info Version:
<empty>
Location: file:///C:/Program Files (x86)/Texas Instruments/Fusion Digital Power Designer/bin/Free.Hid.DLL
Public Key Token:
Free.Misc
Info Version:
<empty>
Location: file:///C:/Program Files (x86)/Texas Instruments/Fusion Digital Power Designer/bin/Free.Misc.DLL
Public Key Token:
Free.WinForms.Misc
Info Version:
<empty>
Location: file:///C:/Program Files (x86)/Texas Instruments/Fusion Digital Power Designer/bin/Free.WinForms.Misc.DLL
Public Key Token:
Version: 7.0.25.0
Info Version:
<empty>
Location: file:///C:/Program Files (x86)/Texas Instruments/Fusion Digital Power Designer/bin/Fusion Digital Power Designer.exe
Public Key Token:
Microsoft.GeneratedCode
Version: 1.0.0.0
Info Version:
<empty>
Location: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
Public Key Token:
Microsoft.VisualBasic
Version: 10.0.0.0
Info Version:
<empty>
Location: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
Public Key Token: B03F5F7F11D50A3A
mscorlib
Version: 4.0.0.0
Info Version:
4.7.3130.0
Location: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
Public Key Token: B77A5C561934E089
System
Version: 4.0.0.0
Info Version:
4.7.2634.0
Location: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Configuration
Version: 4.0.0.0
Info Version:
4.7.2558.0
Location: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Core
Version: 4.0.0.0
Info Version:
4.7.2671.0
Location: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
System.Data
Version: 4.0.0.0
Info Version:
4.7.2623.0
Location: file:///C:/Windows/Microsoft.Net/assembly/GAC_32/System.Data/v4.0_4.0.0.0__b77a5c561934e089/System.Data.dll
System.Data.DataSetExtensions
Version: 4.0.0.0
Info Version:
4.7.2558.0
Location: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Data.DataSetExtensions/v4.0_4.0.0.0__b77a5c561934e089/System.Data.DataSetExtensions.dll
System.Drawing
Version: 4.0.0.0
Info Version:
4.7.2558.0
Location: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Numerics
Version: 4.0.0.0
Info Version:
4.7.2558.0
Location: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Numerics/v4.0_4.0.0.0__b77a5c561934e089/System.Numerics.dll
System.Web
Version: 4.0.0.0
Info Version:
4.7.2623.0
Location: file:///C:/Windows/Microsoft.Net/assembly/GAC_32/System.Web/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Web.dll
Version: 4.0.0.0
Info Version:
4.7.2558.0
Location: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Xml
Version: 4.0.0.0
Info Version:
4.7.2612.0
TIDP.DevEx.Skin1
Version: 1.0.0.0
Info Version:
<empty>
Location: file:///C:/Program Files (x86)/Texas Instruments/Fusion Digital Power Designer/bin/TIDP.DevEx.Skin1.DLL
Public Key Token: 95FC6C5621878F0A
TIDP.Misc
Version: 7.0.0.21531
Info Version:
<empty>
Location: file:///C:/Program Files (x86)/Texas Instruments/Fusion Digital Power Designer/bin/TIDP.Misc.DLL
Public Key Token:
TIDP.Net.ProxyPrefs
Version: 1.4.0.0
Info Version:
<empty>
Location: file:///C:/Program Files (x86)/Texas Instruments/Fusion Digital Power Designer/bin/TIDP.Net.ProxyPrefs.DLL
Public Key Token:
TIDP.PMBus
Version: 7.0.0.21638
Info Version:
<empty>
Location: file:///C:/Program Files (x86)/Texas Instruments/Fusion Digital Power Designer/bin/TIDP.PMBus.DLL
Public Key Token:
TIDP.PMBus.Design.TimeModel
Version: 2.0.88.21532
Info Version:
<empty>
Location: file:///C:/Program Files (x86)/Texas Instruments/Fusion Digital Power Designer/bin/TIDP.PMBus.Design.TimeModel.DLL
Public Key Token:
TIDP.PMBus.DeviceGUI.UCD3000
Version: 7.0.0.21654
Info Version:
<empty>
Location: file:///C:/Program Files (x86)/Texas Instruments/Fusion Digital Power Designer/bin/TIDP.PMBus.DeviceGUI.UCD3000.DLL
Public Key Token:
TIDP.PMBus.ParameterControls
Version: 7.0.0.21652
Info Version:
<empty>
Location: file:///C:/Program Files (x86)/Texas Instruments/Fusion Digital Power Designer/bin/TIDP.PMBus.ParameterControls.DLL
Public Key Token:
TIDP.PMBus.WinForms
Version: 7.0.0.21653
Info Version:
<empty>
Location: file:///C:/Program Files (x86)/Texas Instruments/Fusion Digital Power Designer/bin/TIDP.PMBus.WinForms.DLL
Public Key Token:
TIDP.SAA
Info Version:
<empty>
Location: file:///C:/Program Files (x86)/Texas Instruments/Fusion Digital Power Designer/bin/TIDP.SAA.DLL
Public Key Token:
TIDP.SAA.WinForms.Misc
Version: 2.0.88.21533
Info Version:
<empty>
Location: file:///C:/Program Files (x86)/Texas Instruments/Fusion Digital Power Designer/bin/TIDP.SAA.WinForms.Misc.DLL
Public Key Token:
Version: 7.0.0.21655
Info Version:
<empty>
Location: file:///C:/Program Files (x86)/Texas Instruments/Fusion Digital Power Designer/bin/TIDP.WinForms.Apps.DPGUI.DLL
Public Key Token:
TIDP.WinForms.Apps.DPGUI.DPGUI1
Version: 7.0.0.34321
Info Version:
<empty>
Location: file:///C:/Program Files (x86)/Texas Instruments/Fusion Digital Power Designer/bin/TIDP.WinForms.Apps.DPGUI.DPGUI1.DLL
Public Key Token:
TIDP.WinForms.Apps.DPGUI.HelpCenter
Version: 7.0.0.21533
Info Version:
<empty>
Location: file:///C:/Program Files (x86)/Texas Instruments/Fusion Digital Power Designer/bin/TIDP.WinForms.Apps.DPGUI.HelpCenter.DLL
Public Key Token:
TIDP.WinForms.Dundas
Info Version:
<empty>
Location: file:///C:/Program Files (x86)/Texas Instruments/Fusion Digital Power Designer/bin/TIDP.WinForms.Dundas.DLL
Public Key Token:
TIDP.WinForms.Misc
Info Version:
<empty>
Location: file:///C:/Program Files (x86)/Texas Instruments/Fusion Digital Power Designer/bin/TIDP.WinForms.Misc.DLL
Public Key Token:
TIDP.WinForms.Util
Info Version:
<empty>
Location: file:///C:/Program Files (x86)/Texas Instruments/Fusion Digital Power Designer/bin/TIDP.WinForms.Util.DLL
Public Key Token:
XtraDataTempAssembly
Version: 0.0.0.0
Info Version:
<empty>
Location: file:///C:/Program Files (x86)/Texas Instruments/Fusion Digital Power Designer/bin/DevExpress.Data.v6.2.dll
Public Key Token:
