1. As the following schematic, set LCD_BL_EN as 3.3V, LCD_AVDD is about 4.8V. But VGH, VGL, VOM is almost 0,TPS65105 doesn't work.
2. When connect drain and source port of Q5 PMOS together,TPS65105 can work,AVDD, VGL, VOM is as the value expected.
but VGH is around 20V not as expected,remove C445, and connect C2-/MODE to ground, VGH is normal as expected.(16V)
So, what's the problems with this circuit?
